On Now from Web Admin Screen
v 2022.04.28.1311
From the Web Admin screen:
  • Go to Live TV/Guide - Change the Source to one that has no favorites
  • Go to Live TV/On Now
At this point you get a message that says "No favorite channels found. Add some first."
There is no control on the screen to change the Source and there is no label that tells you what Source is selected. You have to go back and change the source from Live TV/Guide.
Not a major issue, but needs some cleanup.
Good find. I didn't know you could select sources for On Now.
That brings up another issue I've noticed.
This DVR has 3 sources, TVE and 2 single channel M3U's.
It also sees my HDHR Prime, but it's not enabled (no guide provider selected).
Selecting a source in Live TV > Guide doesn't work as expected.
HDHR Prime is selectable but results in a spinning circle since no guide data associated with it.
Selecting either M3U source displays both of them in the guide.
Channels Source MeTV
Channels Source TCM
