Ongoing intermittent playback problem
I've had an ongoing intermittent problem when watching recorded OTA programs. about 1 out out of 5 times I select a show from "up Next", then "Watch", the label with time line appears at the bottom, but the animated circle goes around & doesn't start unless I press the right arrow, which advances 30 seconds, then the show plays.This doesn't seem to be hardware related. I first installed the app on a windows 10 desktop, then moved to a Raspberry PI, and recently to a windows 11 mini pc. I moved the HDD from machine to machine also & finally replaced it on the mini pc, along with the external drive enclosure but the problem continues. I checked the logs & didn't find anything. This server only feeds one Firecube, which I haven't replaced. I think I've updated all software. I assume I have something misconfigued. Thanks for your help.
Try:
Settings > Playback > Advanced > Video Decoder: Software
Thanks, I’ll try that, it was set to hardware.
