Onn media device
Is anyone using channels DVR with the $20 onn media device from Walmart? Do you have any problems with it?
Works fine for most things. ATSC 3.0 channels don't play back great though
Yeah...I have the Onn Pro in the living room and while a tad bit more expensive, its also more powerful and have more space. I have better experience using that compared to the $20 puck
Been using them for a while. Experience isn't as good as ATV but it works fine for the most part. Most issues I have with them is more than likely due to Wi-Fi instead of wired connections.
Onn is okay
