I started using Android Beta on Tivo Stream 4K because Channels Button Detector is no longer available in store version. I think there is a problem starting with v2022.01.18.2308 Possible fix for Skip Commercial button glitching in player. The on screen display timeline doesn't show up when changing channels or pausing, etc. Is there a way to install the beta before version 2308?
Possible fix in v2022.01.19.2217 uploading now
The new beta fixed the issue thank you!
