OTA and TVR issue with ABC
Experiencing one OTA and TVR channel that has been problems lately.
ABC OTA gives “Unknown Channel” only if I turn off TVR sources, but still get guide data for it. After enabling TVR I get 1025 error.
On your DVR web UI click TVE Source > Rescan and click the rescan button next to ABC
still get the same error
Then ABC doesn't work in your area. It should be disabled now so it won't conflict with your OTA.
How do I disable TVA channels?
If you did what I told you it should have disabled itself.
You can select Manage Lineup next to the TVE source and click the cancel icon on the left next to any channel
