Using Channels on Win 11 DVR server - Shield Pro - Channels 9.1.1. I upgraded to a HD Homerun Flex 4K for the additional tuners.
Since the upgrade intermittently the OTA stations disappear from the guide and in the sources HD Homerun it shows zero channels. re-scanning from the Shield client brings them back. Sometimes they will return on their own. They are available from the Win 11 interface and are available from my Apple 4K client.
The device shows in the Sources and is enabled but the channels are missing until re-scanning.
If I disable the HD Homerun in the sources exit Channels and re-enable the HD Homerun the channels will be back.
I have re-installed the old 2 tuner Homerun and re-installed the 4 tuner Homerun with the same result.
HD Homerun Flex 4K has the latest firmware, 20230303.
I do periodically see a message quickly flash on the screen "Lost Connection"
Any ideas?
