I tried connecting the coax to the ups, then to the tuner...and it cut all channels signal strength in half or more. And fully blocked some channels.
I will have to se about trying the grounding block and a power cable...I had of of those ground block somewhere already have those ends and cables from other projects...
I also wonder, if it is worth replacing/upgrading the Channel Master LTE filter I have.
I see on their website that they have a LTE/5G one now.
BUT, its labeled as the same model number as the one i have, CM-3201.
Also, discrepancy on their website on the product image vs the product specs listed below the image.
Image says: Pass: 5 - 608mhz Block: 609 - 3000mhz
Spec page says: Pass: 5 - 609mhz Block: 610 - 2000 MHz
The non 5G one i have has printed on it:
Pass: 5 - 599mhz Block: 600 - 2000mhz
EDIT: So i emailed Channel Master about that issue.
Decided to order the new 5g LTE filter also their High Pass filter, see if either of those, or both helps my issues at all.
