Picked up one of those grounding blocks.
Attached a 3 prong power cord to it, just the green ground wire.
Put it inline of the coax, right at the tuner, plugged the cord into my ups outlet that is grounded(tested with outlet tester) also tried direct to the wall outlet, not UPS.
Tried right at the end of the short built in cable of the on the antenna, where my coax connects to it, plugged cord into wall outlet. Even tried just a wire wrapped around the water pipe in the floorboard radiator heat to the ground block.
No change.
So....its not a grounding problem.
