This is a specific problem not a general one.
I have SD Flex 4 tuner set up. CBS has begun showing "The Price is Right at Night" on Mondays and Fridays. The show is on my guide and I can select it from there and set up a season pass. The pass shows up in my list of passes.
However, when I look through my guide the show is not set up to record and low and behold it does not get recorded.
I would like to be able to record all of these shows without going in every week and doing manual recordings. Is there something that can be done?
Other hints: For this show I use PlayOn Cloud if I completely miss the showing (via Paramount+). Searching for "The Price is Right at Night" on that app returns no hits. In order to record this on PlayOn Cloud I search for The Price is Right and then "at Night" shows are listed there. So it looks like CBS lists both of these shows under Price Is Right. However, my "The Price is Right" season pass does not pick up the evening shows. I have just changed my The Price Is Right season pass to record all shows instead of just new ones. I will report back if this solves the issue.
