the files are just normal media files u can put on any media player device or computer.
Second, what is your end goal?
If you just want to archive the video files to a disk, then you would burn them to the disk as any other file, u can use the built in OS software to do that.
If you mean u wish to take the video file, and author/convert it to a playable DVD Video Disc, like a DVD movie you would buy....that is much more complex. U need video editing software of some sort that supports that. Like Cyberlink make some simple video Producer programs and burning software. If your recordings are in HD, note that DVD Video does not support HD content, it has to be 720x480. (480p) so the software has to re-encode/convert the whole video file to that lower resolution to be playable in DVD Video format. This needs a fairly decent cpu and some hard drive space to do.
It is a pretty rare thing these days of streaming and casting everything, to want to make digital video files into movie dvd, since nearly all DVD/Bluray machines or tvs sold for years now have a usb port, u can just put the files on a usb stick and plug into player.
Or attach a strembox or chrome cast to a tv for $20.
