PAC 12 channels on TVE not working
When i go to play the stream apparently the feed is getting an error 504.
I'm on vidgo with the plus plan.
Just checked with Spectrum and getting the same error.
Their website states they are doing "scheduled technical maintenance".
Getting a 504 Gateway Timeout error on all PAC12 channels (6185-6191) using Xfinity.
Like daldana7296 said it must be a PAC12 live feed issue since https://pac-12.com/ website says
UPDATE Pac-12 Networks programming may be unavailable due to scheduled technical maintenance.
Thanks so much.
I just wanted to make the issue known in case a problem existed.
still not working as of Monday 6/26
xfinity TVE
Wonder how long their "scheduled technical maintenance" takes?
tuned in to the stream on Vidgo and it is working.
Might have to move those channels over to the new project.
still a NO-GO on the various Pac-12 networks on TVE as of 7/3
2 weeks later and the same message is up there. Any ideas what might be taking so long?
I know as much as you do.
You could ask them how long the scheduled maintenance will take.
https://pac-12.com/
Everything is working now on the Pac-12 networks (for me)
