Please consider padding adjustment buttons for the client interfaces.
Padding can be set by tapping the option and choosing from the set values.
Padding options are a set list and not available to set manually. There's no plan change this.
Bummer, could we at least get a couple of start late options? With the ability to add so many different sources, we see start delays of up to a couple of minutes on some. Not that big a deal, but will make a playlist a little dirty with extra blocks of programming from the previous block. Leaving the couch and going to the other room and logging into the server to tweak a pass is frustrating.
Ultimately after a custom time is input on the server, it would be nice if it became persistent in the default list on the clients. On a single source the padding is quite consistent, but varies greatly between sources, making a one size fits all a little awkward. Thanks
You can get more padding options by editing your pass via the web admin.
We try to keep the client simple. Having a bunch of options there is overwhelming to most people and the smaller set of options is mostly fine for them.
For advanced users with more needs, the web admin usually has more options.
