Padding not working on TVE
I've been missing the last 30 seconds of shows. I've added up to 3 minutes and it's not working
Works for me.
Which channel are you having issues on?
Animal planet, Nat Geo wild, NBC, all TVE
Does the log show the recordings ending 3 minutes after they're supposed to? Did you set the 3 minute padding on the passes for those channels?
I'll have to check logs later, but I set 3 minutes for everything
The default end padding setting only affects new passes, not passes created before you changed it.
That makes sense, so I have to delete the schedule?
I think just updating the Passes individually should do it.
