Padding options
Would it be feasible to add a few more padding options for the end of a program between the 30 min and 60 min options that already exist? For my HDHR conditions, I have a limited number of tuners and I've found that if my default start padding for recordings is 3 minutes, that a good complimenting end padding option might be 45, 50, or 55 mins.
With sporting events I like to take the padding as far into the following hour as possible without affecting the recordings for the hour just beyond that. Or maybe there is a way to edit the padding number of minutes manually to just dial in whatever the user might need?
You can set custom padding in an advanced pass.
PassPadCustom2
Could that be an option for individual recordings, when just a single show is selected in the guide?
I voted for it
Added my vote too.
