If I have a show that ends at 8:00 and I pad the ending by 30 seconds but the next show starts at 8:00, what happens? Does it use another tuner to record the show that starts at 8:00?
No it shares the same tuner for the overlapping parts.
So, the server records off the same tuner twice for that 1 minute? I guess that makes sense since it can record more than one show at once.
I was a bit confused about your latest reply.
For clarification for new users: The above padding/recording utilizing only one tuner works as long as both shows are on the same channel.
I was testing this for recording OTA Football. I have a 2 tuner HDhomerun Extend and started 2 recordings and padded the end time 30 min. Then I scheduled the following show on each channel. However the 2nd scheduled recordings failed. The error log is below.
Should this be working with tuner sharing?
2019/09/23 15:10:00 [ERR] Failed to start stream on channel 8.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:10:00 [DVR] Error running job 1569268800-ch8.1 Daily Blast Live: could not start stream on channels=[8.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:10:00 [DVR] Starting job 1569268800-ch4.1 TMZ Live on ch=[4.1]
2019/09/23 15:10:00 [ERR] Failed to start stream on channel 4.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:10:00 [DVR] Error running job 1569268800-ch4.1 TMZ Live: could not start stream on channels=[4.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:10:00 [DVR] Starting job 1569268800-ch8.1 Daily Blast Live on ch=[8.1]
2019/09/23 15:10:00 [DVR] Waiting 3h49m59.5532579s until next job 1569283200-146 NFL Football
2019/09/23 15:10:00 [DVR] Waiting 3h49m59.5413309s until next job 1569283200-146 NFL Football
2019/09/23 15:10:00 [DVR] Waiting 3h49m59.5243762s until next job 1569283200-146 NFL Football
2019/09/23 15:10:00 [DVR] Waiting 3h49m59.5203858s until next job 1569283200-146 NFL Football
2019/09/23 15:10:00 [DVR] Waiting 3h49m59.5144026s until next job 1569283200-146 NFL Football
Maybe you have some other software also trying to use your tuners? Check my.hdhomerun.com under Tuner Status.
Also make sure the transcoding setting is the same on the DVR and in the app.
I'm not using the App. I'm just recording in the DVR. This is 2 tuner HDhomerun and both tuners were used by Channels DVR for the 2 current recordings. So it seems since I padded the current recordings +30 min the next scheduled recordings on the same channels failed because the tuners were still in use by the first recordings. I thought the tuner sharing would kick in when the next scheduled recording started on the same channel.
You didn't include the earlier logs so I can't see what channels were being used for the earlier recordings with padding. Overlapping recordings will use tuner sharing.
Below are the log entries from the time the first recordings started. Both shows on channel 4.1 and 8.1 had padding +30 min.
2019/09/23 14:42:30 [DVR] Starting job 1569265200-ch4.1 The Dr. Oz Show on ch=[4.1]
2019/09/23 14:42:30 [DVR] Waiting 4h17m29.026404s until next job 1569283200-146 NFL Football
2019/09/23 14:42:31 [TNR] Opened connection to 10560E57 for ch4.1 KDFW-DT
2019/09/23 14:42:31 [DVR] Recording for job 1569265200-ch4.1 from 10560E57 ch4.1 into "TV\The Dr. Oz Show\The Dr. Oz Show S11E11 2019-09-23 Oz Exclusive Fertility MixUp Nightmare My Son Was Born to Another Woman 2019-09-23-1442.mpg" for 47m29.026404s
2019/09/23 14:42:31 [DVR] Refreshing metadata for The Dr. Oz Show (3621559)
2019/09/23 14:42:36 [IDX] Generating video index for job 1569265200-ch4.1
2019/09/23 14:42:38 [DVR] Waiting 17m21.0569566s until next job 1569268800-ch4.1 TMZ Live
2019/09/23 14:42:49 [DVR] Starting job 1569267000-ch8.1 Inside Edition on ch=[8.1]
2019/09/23 14:42:49 [DVR] Waiting 17m10.5676328s until next job 1569268800-ch4.1 TMZ Live
2019/09/23 14:42:49 [TNR] Opened connection to 10560E57 for ch8.1 WFAA
2019/09/23 14:42:49 [DVR] Recording for job 1569267000-ch8.1 from 10560E57 ch8.1 into "TV\Inside Edition\Inside Edition S32E11 2019-09-23 Cemetery Thefts 2019-09-23-1442.mpg" for 47m10.5676328s
2019/09/23 14:42:49 [IDX] Generating video index for job 1569267000-ch8.1
2019/09/23 14:42:53 [DVR] Waiting 17m6.8614721s until next job 1569268800-ch4.1 TMZ Live
2019/09/23 14:59:22 [NAT] Successfully mapped port 8089 using natpmp
2019/09/23 15:00:00 [DVR] Starting job 1569268800-ch4.1 TMZ Live on ch=[4.1]
2019/09/23 15:00:00 [ERR] Failed to start stream on channel 4.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:00:00 [DVR] Error running job 1569268800-ch4.1 TMZ Live: could not start stream on channels=[4.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:00:00 [DVR] Starting job 1569268800-ch8.1 Daily Blast Live on ch=[8.1]
2019/09/23 15:00:00 [DVR] Waiting 3h59m59.9927082s until next job 1569283200-146 NFL Football
2019/09/23 15:00:00 [ERR] Failed to start stream on channel 8.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:00:00 [DVR] Error running job 1569268800-ch8.1 Daily Blast Live: could not start stream on channels=[8.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:00:30 [DVR] Starting job 1569268800-ch4.1 TMZ Live on ch=[4.1]
2019/09/23 15:00:30 [ERR] Failed to start stream on channel 4.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:00:30 [DVR] Error running job 1569268800-ch4.1 TMZ Live: could not start stream on channels=[4.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:00:30 [DVR] Starting job 1569268800-ch8.1 Daily Blast Live on ch=[8.1]
2019/09/23 15:00:30 [DVR] Waiting 3h59m29.9755237s until next job 1569283200-146 NFL Football
2019/09/23 15:00:30 [ERR] Failed to start stream on channel 8.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:00:30 [DVR] Error running job 1569268800-ch8.1 Daily Blast Live: could not start stream on channels=[8.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:00:30 [DVR] Waiting 3h59m29.9685423s until next job 1569283200-146 NFL Football
2019/09/23 15:01:00 [DVR] Starting job 1569268800-ch4.1 TMZ Live on ch=[4.1]
2019/09/23 15:01:00 [ERR] Failed to start stream on channel 4.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:01:00 [DVR] Error running job 1569268800-ch4.1 TMZ Live: could not start stream on channels=[4.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:01:00 [DVR] Starting job 1569268800-ch8.1 Daily Blast Live on ch=[8.1]
2019/09/23 15:01:00 [DVR] Waiting 3h58m59.9575169s until next job 1569283200-146 NFL Football
2019/09/23 15:01:00 [ERR] Failed to start stream on channel 8.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:01:00 [DVR] Error running job 1569268800-ch8.1 Daily Blast Live: could not start stream on channels=[8.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:01:00 [DVR] Waiting 3h58m59.9502796s until next job 1569283200-146 NFL Football
2019/09/23 15:01:30 [DVR] Starting job 1569268800-ch4.1 TMZ Live on ch=[4.1]
2019/09/23 15:01:30 [ERR] Failed to start stream on channel 4.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:01:30 [DVR] Error running job 1569268800-ch4.1 TMZ Live: could not start stream on channels=[4.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:01:30 [DVR] Starting job 1569268800-ch8.1 Daily Blast Live on ch=[8.1]
2019/09/23 15:01:30 [DVR] Waiting 3h58m29.9513667s until next job 1569283200-146 NFL Football
2019/09/23 15:01:30 [ERR] Failed to start stream on channel 8.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:01:30 [DVR] Error running job 1569268800-ch8.1 Daily Blast Live: could not start stream on channels=[8.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:01:30 [DVR] Waiting 3h58m29.9453829s until next job 1569283200-146 NFL Football
2019/09/23 15:01:30 [DVR] Waiting 3h58m29.9307678s until next job 1569283200-146 NFL Football
2019/09/23 15:01:30 [DVR] Waiting 3h58m29.9247844s until next job 1569283200-146 NFL Football
2019/09/23 15:02:00 [DVR] Starting job 1569268800-ch4.1 TMZ Live on ch=[4.1]
2019/09/23 15:02:00 [ERR] Failed to start stream on channel 4.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:02:00 [DVR] Error running job 1569268800-ch4.1 TMZ Live: could not start stream on channels=[4.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:02:00 [DVR] Starting job 1569268800-ch8.1 Daily Blast Live on ch=[8.1]
2019/09/23 15:02:00 [DVR] Waiting 3h57m59.9406462s until next job 1569283200-146 NFL Football
2019/09/23 15:02:00 [ERR] Failed to start stream on channel 8.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:02:00 [DVR] Error running job 1569268800-ch8.1 Daily Blast Live: could not start stream on channels=[8.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:02:00 [DVR] Waiting 3h57m59.9298111s until next job 1569283200-146 NFL Football
2019/09/23 15:02:00 [DVR] Waiting 3h57m59.9016247s until next job 1569283200-146 NFL Football
2019/09/23 15:02:00 [DVR] Waiting 3h57m59.8927899s until next job 1569283200-146 NFL Football
2019/09/23 15:02:30 [DVR] Starting job 1569268800-ch4.1 TMZ Live on ch=[4.1]
2019/09/23 15:02:30 [ERR] Failed to start stream on channel 4.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:02:30 [DVR] Error running job 1569268800-ch4.1 TMZ Live: could not start stream on channels=[4.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:02:30 [DVR] Starting job 1569268800-ch8.1 Daily Blast Live on ch=[8.1]
2019/09/23 15:02:30 [DVR] Waiting 3h57m29.9335963s until next job 1569283200-146 NFL Football
2019/09/23 15:02:30 [ERR] Failed to start stream on channel 8.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:02:30 [DVR] Error running job 1569268800-ch8.1 Daily Blast Live: could not start stream on channels=[8.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:02:30 [DVR] Waiting 3h57m29.9196337s until next job 1569283200-146 NFL Football
2019/09/23 15:02:30 [DVR] Waiting 3h57m29.9126521s until next job 1569283200-146 NFL Football
2019/09/23 15:02:30 [DVR] Waiting 3h57m29.9066686s until next job 1569283200-146 NFL Football
2019/09/23 15:02:30 [DVR] Waiting 3h57m29.8926681s until next job 1569283200-146 NFL Football
2019/09/23 15:02:30 [DVR] Waiting 3h57m29.8867201s until next job 1569283200-146 NFL Football
2019/09/23 15:02:30 [DVR] Waiting 3h57m29.8797401s until next job 1569283200-146 NFL Football
2019/09/23 15:02:30 [DVR] Waiting 3h57m29.8721579s until next job 1569283200-146 NFL Football
2019/09/23 15:03:00 [DVR] Starting job 1569268800-ch4.1 TMZ Live on ch=[4.1]
2019/09/23 15:03:00 [ERR] Failed to start stream on channel 4.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:03:00 [DVR] Error running job 1569268800-ch4.1 TMZ Live: could not start stream on channels=[4.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:03:00 [DVR] Starting job 1569268800-ch8.1 Daily Blast Live on ch=[8.1]
2019/09/23 15:03:00 [DVR] Waiting 3h56m59.9174028s until next job 1569283200-146 NFL Football
2019/09/23 15:03:00 [ERR] Failed to start stream on channel 8.1 via 10560E57: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:03:00 [DVR] Error running job 1569268800-ch8.1 Daily Blast Live: could not start stream on channels=[8.1]: HDHomeRun: 805 All Tuners In Use
2019/09/23 15:03:00 [DVR] Waiting 3h56m59.9014428s until next job 1569283200-146 NFL Football
2019/09/23 15:03:00 [DVR] Waiting 3h56m59.8944839s until next job 1569283200-146 NFL Football
2019/09/23 15:03:00 [DVR] Waiting 3h56m59.8885052s until next job 1569283200-146 NFL Football
2019/09/23 15:03:00 [DVR] Waiting 3h56m59.8795286s until next job 1569283200-146 NFL Football
2019/09/23 15:03:00 [DVR] Waiting 3h56m59.8735451s until next job 1569283200-146 NFL Football
This was a bug affecting the EXTEND only and has been fixed in the latest DVR build.
Sorry, I thought I was on the latest build. I updated to the latest build and confirmed tuner sharing is working when padding is added to back to back recordings on same channel. Thank you! for you're quick assistance.
The bug was only fixed in the past hour after you reported it =)
