I have this same issue to. I'm new to Channels DVR, but the creating "pass" for shows I want to record seems fairly streight forward. But, after the intial recording , nothing else is recorded unless I manualy record the show.
I must be doing sometng wrong, but What?
New episodes, keep all, any channel
Try getting rid of New only.
If that doesn't work, it's usually bad guide data that doesn't identify each episode as unique.
For one that doesn't work, what is the source for your pass and what do the settings look like?
hello,
look like that is helping. So, "New" is broken?
The problem is that the guide data that is provided to Channels does not always properly have the "New" tag when it should. It is not something that is broken in Channels, it's just incorrect data that is fed into Channels.
One thing to keep in mind with Channels DVR is that it will not record the same episode twice (if it's still present in your library).
Knowing this + the fact that you can't rely on the "New" tag to be present in the guide, I don't bother anymore selecting the "New" option for my recordings. I simply record all episodes.
And it will not record it again even if you delete it (unless your pass is set to re-record deleted).
thanks both of you for this information
Qouestion, is it possible to use a different guidr data provider? He one from Zapperbox seems to be better and avert the "no recording" problem.
