Pass Recording do not work from guide lists provided by schedules direct
Hi, i have an issue recording from a pass for any program from a channel that have a list provided by schedules direct.
I have another guide list provider with the same channel that does not have this issue.
The same program (En Contacto) appears on the guide but one channel is able to record it with the pass and the other does not.
For the Channel 11001
Here is the guide info on the xml:
  <channel id="guide2go.60332.schedulesdirect.org">
    <display-name>ECUAVG</display-name>
    <display-name>Ecuavisa Guayaquil</display-name>
    <icon src="https://schedulesdirect-api20141201-logos.s3.dualstack.us-east-1.amazonaws.com/stationLogos/s60332_dark_360w_270h.png" height="270" width="360"></ic>
  </channel>
  </programme>
  <programme channel="guide2go.60332.schedulesdirect.org" start="20231229153000 +0000" stop="20231229180000 +0000">
    <title lang="es">En contacto</title>
    <sub-title lang="es">Revista familiar dirigida a las amas de casa.</sub-title>
    <desc lang="es">Revista familiar dirigida a las amas de casa, presentada de una forma amena y familiar de contenido útil para el televidente en la que se mostr>
    <credits></credits>
    <category lang="en">Newsmagazine</category>
    <category lang="en">Variety</category>
    <language>es</language>
    <episode-num system="dd_progid">SH00827331.0000</episode-num>
    <episode-num system="original-air-date">2006-04-17</episode-num>
    <video></video>
    <audio></audio>
    <previously-shown start="2006-04-17"></previously-shown>
  </programme>
and for the Channel the channel: 11002
<channel id="ECUAVISA NACIONAL">
<display-name>ECU-Ecuavisa Quito (L)(720)</display-name>
<icon src="https://1.bp.blogspot.com/-A77n66o-FQI/XjcBYqkTzXI/AAAAAAAABBU/uhcdf-8Bmp4WjMiaUtm0f_O5MxQi1KeiACLcBGAsYHQ/s200/1.png" /></channel>
<programme start="20231229103000 -0500" stop="20231229130000 -0500" channel="ECUAVISA NACIONAL" >
<title>En contacto</title>
<desc>Revista familiar dirigida a las amas de casa, presentada de una forma amena y familiar de contenido útil para el televidente e ></desc>
</programme>
This is expected based on your xmltv.
You could use an advanced pass instead with title matches
What is wrong with my xmltv? do i need to reformat it in a different way? I do want to use title pass for this xmltv source. I could do a little coding to convert it in a proper format.
On the dvr web UI make a new advanced pass
Hi, thanks for the help. Using the advanced tab on the pass i was able to fix the matching by changing it from "SeriesID ==" match to a "Title ==" match.
