I set up a recording pass for cbs toledo. It never recorded. I checked the pass schedule saw it was set up to record 62.1 and 11, so it never recorded. I can't seem to only schedule it on 11.1 because when I delete pass and set it up on 11.1 again ,its schedules both channels.
You need to check the DVR Log to see why it failed to record. Having two channels listed is normal. If it didn't record it means neither channel worked.
I was wrong, just checked the schedule and it's only listing 62.1 to record. I set it up on my local toledo 11.1. Both chanbels work but 11 is my strongest channel. Any way to just schedule channel 11. I have a two tuner unit.
I don't have that same screen on the app I have on my nvidia shield. I'll check my account online.
That's more or less what I have with plex.
Thanks
That should do the trick, allowed me to make the changes.
Thank you
