Passes for SRCs HDHR & epg.best playlist/guide links
I have read information on the forum here about using Channels DVR for recording from a HDHR and epg.best provided M3U/guide. I must not be searching correctly or missing something important in the process.
All I want to do is record and/or use passes from both sources and have them both work correctly. Currently passes work on the HDHR while passes do not record on the second source. When I check the passes on second source there is nothing set to record (no matches).
Is there a thread or a doc that outlines how to make this work? Thanks, in advance!!
something like this:
