Hi All
I am in Melbourne, Australia, & trying to set up Channels DVR, with a server on Win10, and clients on a couple of Chromecast With Google TVs, but having EPG issues. I like the interface, so would like to get it working, if possible.
I am using HDHomerun network tuners, and have linked the Channels DVR server to the HDHomerun EPG.
The result? Well, I can see live TV, and see the EPG (14 days), and can set a program to record from the EPG, and it will record that show. I cannot, however, get any 'Passes' to work. The system allows me to set up Passes, and shows them as being set, but then ...no recordings happen.
Under Settings, I can see the Passes, but nothing from the Passes is listed under 'Scheduled Recordings'.
(I also note that the selected 'Pass' shows do not appear flagged as 'to be recorded' in any way in the EPG - I expected a red dot, or different coloured entry, or something.)
Channels Support suggested I update to 'pre-release', which I have done (a few times now), but no change.
I have downloaded logs & emailed to Support, but that also didn't seem to provide any useful information.
As I am not in the US, I thought I'd ask here, as maybe there's a fellow Australian on the forum who has had the same problems. (eg is there something about HDHomerun EPG in Oz I don't know about?)
My Plan B is to try IceTV EPG (local Aussie EPG, which I used back in the Windows MediaCenter days), but not sure exactly how to go about this - is it just a case of inputting the appropriate URL for their XML file, into Channels DVR?
Apologies for the extremely long post & thanks in advance.
Andy
