Pause EyeTV to try Channels DVR?
I only have one Mac mini on which I run EyeTV. Does anyone have any tips for “pausing” EyeTV so that I can try Channels DVR?
I don’t want to delete all my schedules from EyeTV until I’m sure I’m going to keep Channels DVR but OTOH I don’t want EyeTV interfering with Channels DVR and giving me a bad impression.
Can you quit EyeTV?
Not sure as I haven’t used it myself
You can remove the tick next to the clock icon in the schedules library to ‘pause’ scheduled recordings. You can also double click each scheduled recording & click Disable Schedule.
The easiest way to achieve what you want is to select all of the schedules, right click & select Disable Selected Schedules.
