Help please I’m having problems with channels recording poorly – I can watch a live tv stream with HDHomerun OK but recordings of the same channel with ChannelsDVR has skipping and pausing. I’ve reinstalled and powered off and restarted all components and I’m at a loss.
Using QNAP 253 pro firmware 4.3.6.0805
Channels 1.03 (Web page ver 2019.01.26.0601)
Model: HDHR5-4DT
Firmware: 20180817
Regards
Gary
2019/01/26 22:37:49 [NAT] Successfully mapped port 8089 using natpmp
2019/01/26 22:52:19 [DVR] Commercial detection finished with 12 markers.
2019/01/26 23:37:49 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 00:37:49 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 01:37:48 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 02:37:48 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 03:37:48 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 04:37:48 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 05:37:48 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 06:37:48 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 07:37:48 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 08:37:48 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 09:19:45 [SYS] Shutting down...
2019/01/27 09:19:45 [SYS] Bonjour service stopped.
2019/01/27 09:19:45 [DVR] Recording engine stopped.
2019/01/27 09:19:46 [SYS] Goodbye.
2019/01/27 09:20:49 [SYS] Starting Channels DVR v2018.11.20.2224 (linux-x86_64 pid:3763) in /share/CACHEDEV1_DATA/.qpkg/ChannelsDVR/channels-dvr/data
2019/01/27 09:20:50 [HDR] Found 1 devices
2019/01/27 09:20:52 [SYS] Started HTTP Server
2019/01/27 09:20:56 [DVR] Recording engine started in /share/Multimedia/Channels
2019/01/27 09:20:56 [SYS] Bonjour service running for dvr-thecastlesvr.local. [192.168.0.239]
2019/01/27 09:20:56 [DVR] Waiting 8m3.306896092s until next job 1548581340-10 Sunday Brunch
2019/01/27 09:20:56 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 09:20:57 [SYS] Created database snapshot: backup-20190127.092056
2019/01/27 09:21:09 [IDX] Pruned 1443 expired airings from GBR-0004881-DEFAULT in 3.21992634s.
2019/01/27 09:29:00 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:29:00 [DVR] Waiting 10h30m29.985598312s until next job 1548619170-92 Vera
2019/01/27 09:29:01 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:29:01 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 3h5m59.985523348s
2019/01/27 09:29:34 [DVR] Cancelling stream 12502A1B ch104 after 3s read timeout
2019/01/27 09:29:34 [TNR] Closed connection to 12502A1B for ch104
2019/01/27 09:29:34 [DVR] Job 1548581340-10 Sunday Brunch ended prematurely: 3h5m25.502219872s
2019/01/27 09:29:34 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:29:34 [DVR] Waiting 10h29m55.489603588s until next job 1548619170-92 Vera
2019/01/27 09:29:36 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:29:36 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:30:06 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:30:06 [DVR] Waiting 10h29m23.46846976s until next job 1548619170-92 Vera
2019/01/27 09:30:08 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:30:08 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:30:38 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:30:38 [DVR] Waiting 10h28m51.455897416s until next job 1548619170-92 Vera
2019/01/27 09:30:39 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:30:39 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 3h4m21.455846608s
2019/01/27 09:32:53 [DVR] Cancelling stream 12502A1B ch104 after 3s read timeout
2019/01/27 09:32:53 [TNR] Closed connection to 12502A1B for ch104
2019/01/27 09:32:53 [DVR] Job 1548581340-10 Sunday Brunch ended prematurely: 3h2m6.319361884s
2019/01/27 09:32:53 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:32:53 [DVR] Waiting 10h26m36.307465396s until next job 1548619170-92 Vera
2019/01/27 09:32:55 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:32:55 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:33:25 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:33:25 [DVR] Waiting 10h26m4.29242518s until next job 1548619170-92 Vera
2019/01/27 09:33:27 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:33:27 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 3h1m34.292370784s
2019/01/27 09:39:36 [DVR] Cancelling stream 12502A1B ch104 after 3s read timeout
2019/01/27 09:39:36 [TNR] Closed connection to 12502A1B for ch104
2019/01/27 09:39:36 [DVR] Job 1548581340-10 Sunday Brunch ended prematurely: 2h55m23.893064092s
2019/01/27 09:39:36 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:39:36 [DVR] Waiting 10h19m53.876975668s until next job 1548619170-92 Vera
2019/01/27 09:39:38 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:39:38 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:40:08 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:40:08 [DVR] Waiting 10h19m21.864579148s until next job 1548619170-92 Vera
2019/01/27 09:40:09 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:40:09 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 2h54m51.864534604s
2019/01/27 09:42:14 [DVR] Cancelling stream 12502A1B ch104 after 3s read timeout
2019/01/27 09:42:14 [TNR] Closed connection to 12502A1B for ch104
2019/01/27 09:42:14 [DVR] Job 1548581340-10 Sunday Brunch ended prematurely: 2h52m45.125989924s
2019/01/27 09:42:14 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:42:14 [DVR] Waiting 10h17m15.108440752s until next job 1548619170-92 Vera
2019/01/27 09:42:16 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:42:16 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 2h52m45.108391828s
2019/01/27 09:42:53 [DVR] Cancelling stream 12502A1B ch104 after 3s read timeout
2019/01/27 09:42:53 [TNR] Closed connection to 12502A1B for ch104
2019/01/27 09:42:53 [DVR] Job 1548581340-10 Sunday Brunch ended prematurely: 2h52m6.325269832s
2019/01/27 09:42:53 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:42:53 [DVR] Waiting 10h16m36.313509556s until next job 1548619170-92 Vera
2019/01/27 09:42:55 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:42:55 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:43:25 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:43:25 [DVR] Waiting 10h16m4.279370092s until next job 1548619170-92 Vera
2019/01/27 09:43:27 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:43:27 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 2h51m34.279315348s
2019/01/27 09:44:28 [DVR] Cancelling stream 12502A1B ch104 after 3s read timeout
2019/01/27 09:44:28 [TNR] Closed connection to 12502A1B for ch104
2019/01/27 09:44:28 [DVR] Job 1548581340-10 Sunday Brunch ended prematurely: 2h50m31.950512428s
2019/01/27 09:44:28 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:44:28 [DVR] Waiting 10h15m1.934932684s until next job 1548619170-92 Vera
2019/01/27 09:44:30 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:44:30 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:45:00 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:45:00 [DVR] Waiting 10h14m29.92244254s until next job 1548619170-92 Vera
2019/01/27 09:45:01 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:45:01 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 2h49m59.922393616s
2019/01/27 09:46:26 [DVR] Cancelling stream 12502A1B ch104 after 3s read timeout
2019/01/27 09:46:26 [TNR] Closed connection to 12502A1B for ch104
2019/01/27 09:46:26 [DVR] Job 1548581340-10 Sunday Brunch ended prematurely: 2h48m33.659828248s
2019/01/27 09:46:26 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:46:26 [DVR] Waiting 10h13m3.640866856s until next job 1548619170-92 Vera
2019/01/27 09:46:28 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:46:28 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:46:58 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:46:58 [DVR] Waiting 10h12m31.627813312s until next job 1548619170-92 Vera
2019/01/27 09:46:59 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:46:59 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 2h48m1.627747276s
2019/01/27 09:48:48 [SYS] Downloading new version v2019.01.26.0601
2019/01/27 09:48:51 [DVR] Cancelling stream 12502A1B ch104 after 3s read timeout
2019/01/27 09:48:51 [TNR] Closed connection to 12502A1B for ch104
2019/01/27 09:48:51 [DVR] Job 1548581340-10 Sunday Brunch ended prematurely: 2h46m8.52194038s
2019/01/27 09:48:51 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:48:51 [DVR] Waiting 10h10m38.502431212s until next job 1548619170-92 Vera
2019/01/27 09:48:53 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:48:53 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:49:09 [SYS] Update downloaded and verified successfully.
2019/01/27 09:49:09 [SYS] Shutting down for upgrade from v2018.11.20.2224 to v2019.01.26.0601
2019/01/27 09:49:09 [SYS] Bonjour service stopped.
2019/01/27 09:49:09 [DVR] Recording engine stopped.
2019/01/27 09:49:10 [SYS] Starting Channels DVR v2019.01.26.0601 (linux-x86_64 pid:3763) in /share/CACHEDEV1_DATA/.qpkg/ChannelsDVR/channels-dvr/data
2019/01/27 09:49:10 [HDR] Found 1 devices
2019/01/27 09:49:12 [SYS] Started HTTP Server
2019/01/27 09:49:16 [DVR] Recording engine started in /share/Multimedia/Channels
2019/01/27 09:49:16 [SYS] Bonjour service running for dvr-thecastlesvr.local. [192.168.0.239]
2019/01/27 09:49:16 [SYS] Removing old update 2018.11.20.2224
2019/01/27 09:49:16 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:49:16 [DVR] Waiting 10h10m13.967665384s until next job 1548619170-92 Vera
2019/01/27 09:49:16 [NAT] Successfully mapped port 8089 using natpmp
2019/01/27 09:49:16 [SYS] Created database snapshot: backup-20190127.094916
2019/01/27 09:49:18 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:49:18 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:49:26 [IDX] Pruned 36 expired airings from GBR-0004881-DEFAULT in 494.91252ms.
2019/01/27 09:49:48 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:49:48 [DVR] Waiting 10h9m41.954167288s until next job 1548619170-92 Vera
2019/01/27 09:49:50 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:49:50 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:50:20 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:50:20 [DVR] Waiting 10h9m9.941521264s until next job 1548619170-92 Vera
2019/01/27 09:50:22 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:50:22 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:50:52 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:50:52 [DVR] Waiting 10h8m37.92803554s until next job 1548619170-92 Vera
2019/01/27 09:50:53 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:50:53 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 2h44m7.928662732s
2019/01/27 09:52:16 [DVR] Cancelling stream 12502A1B ch104 after 3s read timeout
2019/01/27 09:52:16 [TNR] Closed connection to 12502A1B for ch104
2019/01/27 09:52:16 [DVR] Job 1548581340-10 Sunday Brunch ended prematurely: 2h42m43.94317816s
2019/01/27 09:52:16 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:52:16 [DVR] Waiting 10h7m13.922599396s until next job 1548619170-92 Vera
2019/01/27 09:52:18 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:52:18 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:52:48 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:52:48 [DVR] Waiting 10h6m41.878414888s until next job 1548619170-92 Vera
2019/01/27 09:52:49 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:52:49 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 2h42m11.888739388s
2019/01/27 09:52:54 [DVR] Cancelling stream 12502A1B ch104 after 3s read timeout
2019/01/27 09:52:54 [TNR] Closed connection to 12502A1B for ch104
2019/01/27 09:52:54 [DVR] Job 1548581340-10 Sunday Brunch ended prematurely: 2h42m5.810032576s
2019/01/27 09:52:54 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:52:54 [DVR] Waiting 10h6m35.776024228s until next job 1548619170-92 Vera
2019/01/27 09:52:56 [ERR] Failed to start stream on channel 104 via 12502A1B: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:52:56 [DVR] Error running job 1548581340-10 Sunday Brunch: could not start stream on channels=[104]: Get http://192.168.0.24:5004/auto/v104?: dial tcp 192.168.0.24:5004: i/o timeout
2019/01/27 09:53:26 [DVR] Starting job 1548581340-10 Sunday Brunch on ch=[104]
2019/01/27 09:53:26 [DVR] Waiting 10h6m3.757717972s until next job 1548619170-92 Vera
2019/01/27 09:53:27 [TNR] Opened connection to 12502A1B for ch104
2019/01/27 09:53:27 [DVR] Recording for job 1548581340-10 from 12502A1B ch104 into "TV/Sunday Brunch/Sunday Brunch 2019-01-27 2019-01-27-0929.mpg" for 2h41m33.757679524s
