I don't know if this would be possible, but adding Peacock Premium Plus Local NBC Live Stream would be great.
The antenna TV gets a little tricky with snow in the winter, so an internet version for those months would be great.
Thanks
Thanks
I'm pretty sure getting anything from Peacock directly is not possible due to DRM.
However, you may be able to get your local NBC stream, depending on your TV provider and your TV market.
My TV provider is DirecTV (satellite) and I am in the NYC TV market. I am able to get my local NBC stream in Channels DVR with the DirecTV TVE source.
Thank you for the info,
My streaming service Philo doesn't include NBC, so just looking for a way to add another stream of NBC to Channels for my wife to use easily.
Have a great day
Ah yes, sorry, no luck with Philo.
Could it be an option for you to upgrade your antenna?
Do you know if your over-the-air NBC is on VHF or UHF?
That is a good point and idea
