Percent Symbol Causing Issues
I am getting this error when I try to load a Pass, or open any recordings for the show "The 1% Club". I suspect the title of the show is causing issues for Channels. Not seeing anything in the logs. Thoughts?
Pathname "/admin/shows/The 1% Club ᴺᵉʷ" could not be decoded. This is likely caused by an invalid percent-encoding.
Object.Et [as createLocation]@https://xxx/node_modules/history/cjs/history.min.js:1
createLocation@https://xxx/node_modules/react-router-dom/modules/utils/locationUtils.js:8
normalizeToLocation@https://xxx/node_modules/react-router-dom/modules/Link.js:92
d@https://xxx/node_modules/react-dom/cjs/react-dom.production.min.js:274
ck@https://xxx/node_modules/react-dom/cjs/react-dom.production.min.js:250
bk@https://xxx/node_modules/react-dom/cjs/react-dom.production.min.js:250
ak@https://xxx/node_modules/react-dom/cjs/react-dom.production.min.js:250
Tj@https://xxx/node_modules/react-dom/cjs/react-dom.production.min.js:243
c@https://xxx/node_modules/react-dom/cjs/react-dom.production.min.js:123
b@https://x/node_modules/scheduler/cjs/scheduler.production.min.js:18
I’ve just started using Channels and have the exact same issue with this show. Same error message. It means you can’t use the web interface to manage passes because it falls over. Removing this pass is the only fix which is not ideal. Hopefully this thread revival gets a fix in the works.
Cheers
Yes, just encountered this issue myself today...
Pathname "/admin/shows/The 1% Club" could not be decoded. This is likely caused by an invalid percent-encoding.
Can't access 'Passes' at all due to the '%' symbol. Would be great to get some traction on this bug.
Submit diagnostics so we can help
