Personal Section Help
Not sure if what I'm trying to do is possible or not...I'd like to create a personal section that has filtered TV shows for a couple of genres, then add that to the sidebar in the client.
I can easily create the personal section, but it only appears to show 2 rows before needing to go to "more". Isn't there any way to show all TV shows at once? I can't seem to figure it out.
Nevermind, figured it out :wink:
I needed to create a personal section with a type of “Flow” vs “Multi Row”.
Please explain for others that might find your topic.
