Personal Section Templates question
Have a question regarding the personal section templates...when selecting one of those to create a new personal section, are they just supposed to be a copy of the "out of the box" Movies or TV Shows library views?
For some reason, when I create a new personal section and select a Movie template, it just seems to be sort of a random layout and wondering if my templates got messed up somehow? Just not sure what those templates are supposed to represent.
Thanks in advance
It should. What are you seeing. Showing what you’re actually seeing would be helpful.
I guess they’re not a ton different but this is the regular Movies section
And this is a personal section created from the Movies template. Biggest thing is buttons are missing.
Ignore the duplicate movies - that's because I've got multiple copies.
I was just struggling with how to create buttons from scratch and wanted to use the Movies template as an example. I think I got how to create those figured out though finally.
What I’m really interested in is how to add buttons like this. For example, how can I create a Genres button?
If the template worked then I could see and edit to meet my needs.
Genres button isn’t something you can add.
