Oh ok well that answers that then..Thank you for help
If I use my sisters Xfinity Cable will that work? Do not want her to get in trouble though.
Yes it should. But some people do have issues doing that with xfinity and forced password resets
Sorry one more thing...Do you know any other services like Philo that is not expensive and does have local Network via TV everywhere? That I can enable?
If you choose to do over the air antenna silicon dust HDHomeRun flex 4k or flex duo. The 4k has 4 tuners vs the duoβs 2. You donβt need any of the scribe versions to use with channels dvr. Tuner count is personal preference, obviously the more you have the more shows you can record at the same time. As far as antennas you would pick based on location of towers and whether they broadcast in uhf or vhf
