agreed. If that doesn't work...what else could it be?
I’d turn both the router and the attached drive off for at least ten seconds before powering back on.. if that doesn’t fix it, it would recommend submitting diagnostics from both the client and DVR software after the issue happens to see what the Devs think.
Optimism dude
What brand is the router
nighthawk. No issues since August. Just weird
hope its an easy fix. In general I find drives attached to routers less reliable than a NAS or directly connected drives to a computer
how come that is you think?
Well fellas...with the restarting of the router and hard drive, it appears to be working.
Thoughts as to what happened?
The bus components used in routers, the resources dedicated to the bus. Its not a high priority in routers. Managing traffic is what they prioritise
gotcha. thanks
