nope. this is the log for the past few minutes as I have been playing around with the settings.
2021/01/22 19:54:57.537555 [TNR] Opened connection to TVE-Philo for ch6021 TVLANDP [transcode=none]
2021/01/22 19:55:21.903016 [TNR] Closed connection to TVE-Philo for ch6021 TVLANDP
2021/01/22 19:55:25.767374 [TVE] stream timestamps: paramount: start_at=2021-01-22T19:54:29-08:00 current_at=2021-01-22T19:54:54-08:00 end_at=2021-01-22T19:54:59-08:00
2021/01/22 19:55:25.767436 [TNR] Opened connection to TVE-Philo for ch6022 PARAMOUNT [transcode=none]
2021/01/22 19:55:32.603982 [TNR] Closed connection to TVE-Philo for ch6022 PARAMOUNT
2021/01/22 20:06:44.079785 [TVE] stream timestamps: paramount: start_at=2021-01-22T20:05:46-08:00 current_at=2021-01-22T20:06:12-08:00 end_at=2021-01-22T20:06:16-08:00
2021/01/22 20:06:44.117245 [TNR] Opened connection to TVE-Philo for ch6022 PARAMOUNT [transcode=none]
2021/01/22 20:06:55.997661 [TNR] Closed connection to TVE-Philo for ch6022 PARAMOUNT
2021/01/22 20:11:57.374899 [TVE] stream timestamps: paramount: start_at=2021-01-22T20:11:01-08:00 current_at=2021-01-22T20:11:21-08:00 end_at=2021-01-22T20:11:29-08:00
2021/01/22 20:11:57.423183 [TNR] Opened connection to TVE-Philo for ch6022 PARAMOUNT [transcode=none]
2021/01/22 20:13:03.798299 [TNR] Closed connection to TVE-Philo for ch6022 PARAMOUNT
2021/01/22 20:14:36.959863 [TVE] stream timestamps: paramount: start_at=2021-01-22T20:13:39-08:00 current_at=2021-01-22T20:14:06-08:00 end_at=2021-01-22T20:14:09-08:00
2021/01/22 20:14:36.959925 [TNR] Opened connection to TVE-Philo for ch6022 PARAMOUNT
2021/01/22 20:14:37.157483 [HLS] Starting transcoder for channel 6022 from 192.168.1.27 (encoder=remux, resolution=, deinterlacer=, bitrate=4279)
2021/01/22 20:14:41.978380 [HLS] Probed live stream in 4.758516352s: h264 1920x1080 progressive 4378238bps
2021/01/22 20:14:45.228077 [HLS] Session ch6022-dANY-ip192.168.1.27 started in 11.047126038s
2021/01/22 20:15:25.176208 [HLS] Stopping transcoder session ch6022-dANY-ip192.168.1.27 (out: 15.826456s, finished: false)
2021/01/22 20:15:27.533110 [TNR] Closed connection to TVE-Philo for ch6022 PARAMOUNT
2021/01/22 20:15:57.307521 [TVE] stream timestamps: paramount: start_at=2021-01-22T20:15:00-08:00 current_at=2021-01-22T20:15:27-08:00 end_at=2021-01-22T20:15:30-08:00
2021/01/22 20:15:57.307573 [TNR] Opened connection to TVE-Philo for ch6022 PARAMOUNT [transcode=none]
2021/01/22 20:16:14.778249 [TNR] Closed connection to TVE-Philo for ch6022 PARAMOUNT
2021/01/22 20:20:54.641778 [TVE] stream timestamps: hallmark: start_at=2021-01-22T20:19:53-08:00 current_at=2021-01-22T20:20:35-08:00 end_at=2021-01-22T20:20:47-08:00
2021/01/22 20:20:54.641829 [TNR] Opened connection to TVE-Philo for ch6090 HALLMARK
2021/01/22 20:20:55.044413 [HLS] Starting transcoder for channel 6090 from 192.168.1.50 (encoder=remux, resolution=, deinterlacer=, bitrate=3712)
2021/01/22 20:21:04.264144 [HLS] ffmpeg: ch6090-dANY-ip192.168.1.50-remux: [hls @ 0x2f49cc4c00] Timestamps are unset in a packet for stream 1. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
2021/01/22 20:21:05.426631 [HLS] Probed live stream in 10.087418746s: h264 1280x720 progressive 3206485bps
2021/01/22 20:21:09.275895 [HLS] Session ch6090-dANY-ip192.168.1.50 started in 16.598613536s
2021/01/22 20:21:44.136748 [HLS] Stopping transcoder session ch6090-dANY-ip192.168.1.50 (out: 15.215211s, finished: false)
2021/01/22 20:21:44.137621 [HLS] ffmpeg: ch6090-dANY-ip192.168.1.50-remux: [mpegts @ 0x2f49cc4600] Dropped corrupted packet (stream = 1)
2021/01/22 20:21:45.337428 [TNR] Closed connection to TVE-Philo for ch6090 HALLMARK
2021/01/22 20:32:17.190184 [SYS] Bonjour service stopped.
2021/01/22 20:32:18.549244 [DVR] Recording engine stopped.
2021/01/22 20:32:24.784690 [SYS] Bonjour service running for dvr-shield.local. [192.168.1.27]
2021/01/22 20:32:27.663245 [DVR] Recording engine started in /storage/READYSHARE/USB_Storage/DVR
2021/01/22 20:32:33.952426 [SYS] Created database snapshot: backup-20210122.203229
2021/01/22 20:32:34.036239 [SYS] Removing old backup backup-20201227.100627
2021/01/22 20:32:37.728597 [IDX] Pruned 806 expired airings from USA-OTA91786 in 150.254531ms.
2021/01/22 20:32:37.871135 [IDX] Pruned 1069 expired airings from X-TVE in 142.436615ms.
2021/01/22 20:32:37.948049 [IDX] Pruned 756 expired airings from XMLTV-plutotv in 76.806614ms.
2021/01/22 20:33:19.404905 [TVE] stream timestamps: paramount: start_at=2021-01-22T20:32:23-08:00 current_at=2021-01-22T20:32:43-08:00 end_at=2021-01-22T20:32:51-08:00
2021/01/22 20:33:19.405007 [TNR] Opened connection to TVE-Philo for ch6022 PARAMOUNT [transcode=none]
2021/01/22 20:33:58.947784 [TNR] Closed connection to TVE-Philo for ch6022 PARAMOUNT
2021/01/22 20:34:07.867421 [SYS] Shutting down...
2021/01/22 20:34:07.894471 [SYS] Bonjour service stopped.
2021/01/22 20:34:07.910703 [DVR] Recording engine stopped.
2021/01/22 20:34:08.910884 [SYS] Goodbye.
2021/01/22 20:34:23.142832 [SYS] Starting Channels DVR v2021.01.15.1649 (android-arm64 pid:3695) in /mnt/expand/36e7dbfe-6743-496e-826a-8eb2d960d5dc/user/0/com.getchannels.dvr/files/channels-dvr/data
2021/01/22 20:34:23.200154 [SYS] Started HTTP Server
2021/01/22 20:34:23.698488 [HDR] Found 1 devices
2021/01/22 20:34:25.366216 [DVR] Recording engine started in /storage/READYSHARE/USB_Storage/DVR
2021/01/22 20:34:25.368125 [SYS] Bonjour service running for dvr-shield.local. [192.168.1.27]
2021/01/22 20:34:31.786911 [SYS] Created database snapshot: backup-20210122.203427
2021/01/22 20:34:31.812531 [SYS] Removing old backup backup-20201228.100747
2021/01/22 20:34:35.191003 [IDX] Pruned 0 expired airings from X-TVE in 1.202604ms.
2021/01/22 20:34:35.194524 [IDX] Pruned 1 expired airings from XMLTV-plutotv in 2.931562ms.
2021/01/22 20:34:35.197706 [IDX] Pruned 0 expired airings from USA-OTA91786 in 3.112083ms.
2021/01/22 20:34:45.169200 [TVE] stream timestamps: paramount: start_at=2021-01-22T20:33:48-08:00 current_at=2021-01-22T20:34:13-08:00 end_at=2021-01-22T20:34:20-08:00
2021/01/22 20:34:45.169277 [TNR] Opened connection to TVE-Philo for ch6022 PARAMOUNT [transcode=none]
2021/01/22 20:35:01.583929 [TNR] Closed connection to TVE-Philo for ch6022 PARAMOUNT
2021/01/22 20:35:09.203691 [SYS] Shutting down...
2021/01/22 20:35:09.207844 [SYS] Bonjour service stopped.
2021/01/22 20:35:09.225703 [DVR] Recording engine stopped.
2021/01/22 20:37:04.745754 [SYS] Starting Channels DVR v2021.01.15.1649 (android-arm64 pid:9345) in /mnt/expand/36e7dbfe-6743-496e-826a-8eb2d960d5dc/user/0/com.getchannels.dvr/files/channels-dvr/data
2021/01/22 20:37:05.169998 [SYS] Started HTTP Server
2021/01/22 20:37:05.807135 [HDR] Found 1 devices
2021/01/22 20:37:10.629207 [DVR] Recording engine started in /storage/READYSHARE/USB_Storage/DVR
2021/01/22 20:37:10.630867 [SYS] Bonjour service running for dvr-shield.local. [192.168.1.27]
2021/01/22 20:37:20.877149 [IDX] Pruned 0 expired airings from USA-OTA91786 in 1.006094ms.
2021/01/22 20:37:20.878258 [IDX] Pruned 0 expired airings from X-TVE in 1.031458ms.
2021/01/22 20:37:20.931086 [IDX] Pruned 6 expired airings from XMLTV-plutotv in 52.752604ms.
2021/01/22 20:37:21.527869 [SYS] Created database snapshot: backup-20210122.203716
2021/01/22 20:37:21.571112 [SYS] Removing old backup backup-20201229.100903
2021/01/22 20:37:39.193953 [TRS] DNS: OK: Resolved host via system DNS
2021/01/22 20:37:40.159027 [TRS] Cloud Reachable: OK: Connected to community.getchannels.com
2021/01/22 20:37:40.275745 [TRS] Local Time: OK: Local clock is accurate
2021/01/22 20:37:40.275992 [TRS] Remote Access: OK: Remote access not configured
2021/01/22 20:37:40.927571 [TRS] Disk Permissions: OK
2021/01/22 20:38:42.342472 [SYS] Downloading new version v2021.01.22.2156
2021/01/22 20:38:51.096187 [SYS] Update downloaded and verified successfully.
2021/01/22 20:38:51.096223 [SYS] Shutting down for upgrade from v2021.01.15.1649 to v2021.01.22.2156
2021/01/22 20:38:51.097304 [SYS] Bonjour service stopped.
2021/01/22 20:38:51.099231 [DVR] Recording engine stopped.
2021/01/22 20:38:52.440964 [SYS] Starting Channels DVR v2021.01.22.2156 (android-arm64 pid:9345) in /mnt/expand/36e7dbfe-6743-496e-826a-8eb2d960d5dc/user/0/com.getchannels.dvr/files/channels-dvr/data
2021/01/22 20:38:52.481082 [SYS] Started HTTP Server
2021/01/22 20:38:52.980899 [HDR] Found 1 devices
2021/01/22 20:38:55.345493 [DVR] Recording engine started in /storage/READYSHARE/USB_Storage/DVR
2021/01/22 20:38:55.348137 [SYS] Bonjour service running for dvr-shield.local. [192.168.1.27]
2021/01/22 20:38:55.349493 [SYS] Removing old update 2020.07.17.0024
2021/01/22 20:39:02.178351 [SYS] Created database snapshot: backup-20210122.203858
2021/01/22 20:39:02.220335 [SYS] Removing old backup backup-20201230.101032
2021/01/22 20:39:05.812360 [IDX] Pruned 0 expired airings from USA-OTA91786 in 1.910365ms.
2021/01/22 20:39:05.829789 [IDX] Pruned 1 expired airings from X-TVE in 17.317604ms.
2021/01/22 20:39:05.857745 [IDX] Pruned 1 expired airings from XMLTV-plutotv in 27.811406ms.
2021/01/22 20:39:36.969049 [TVE] stream timestamps: paramount: start_at=2021-01-22T20:38:38-08:00 current_at=2021-01-22T20:38:58-08:00 end_at=2021-01-22T20:39:06-08:00
2021/01/22 20:39:37.014618 [TNR] Opened connection to TVE-Philo for ch6022 PARAMOUNT [transcode=none]
