Philo tve issues
Anyone using philo having tve issues? Most channels have either technical difficulties or say the program isn't available for streaming.
Started about an hour ago.
Sample channels with issues.
Comedy central
Science
Investigation Discovery
Trvl
Does it work on http://www.cc.com/live-tv
Yes it works fine
Also, I rescanned the source....still authenticates and I have the same number of channels. Same message though.
Wife pissed, missing Dr phil :slight_smile:
Some of the channels have come back After I logged in to the channel directly. Seems odd....today is also the day my service renews as well. Could that have anything to do with it? Email said I was charged...
Hall mark channels do not work for me using Philo.
2020/09/01 16:13:37.924117 [ERR] Could not start stream for TVE-Philo ch6091 HALLMARKMM: TVE: get: https://crownmediaingest.akamaized.net/hls/live/567739/mm/master_664k.m3u8?hdntl=exp=1599023616~acl=%2F*~hmac=e80b604b8bde137cdd6b6acf60f4d7e5e44ef36ec1f130ef6541a8a3673e85e2: 404 Not Found
All other Philo provided TVE works fine for me.
The new Hallmark Drama channel, works fine via Xfinity TVe though
Did you rescan them after the update?
Thought this was unrelated to other thread....i see u posted there to update..i did, no change, but i missed the info to rescan.
works now
thanks.
