Yeah I’ll grab one later, although I did capture a video before and the issue is harder to see (I guess differing refresh rates from the iPhone and TV broadcast). I see it every 20 seconds or so.
Does it happen on both HD and SD channels?
Never mind you already said it happens on both.
Let me try to make some changes in the beta this week to see if it helps.
Thank you, really appreciate that
Hi
I’ve just emailed you (to [email protected]) a clip with the subject ‘RE: Picture Jerkiness (from forum)’.
Thanks
This should be fixed as of the latest beta.
Like I said in my email, it’s looking good!!
Does this mean that I can use the Favourites pull-down menu now, and add more favourites?
Thanks
Yes, please use the app as normal now and report any problems.
Excellent. Thanks again for your continued and unrelenting support!
