I have submitted diagnostic log 5f50f24c-ec0f-4b8e-b309-db5cfe52efdb I have been having an issue for some time when playing back recordings that the recording randomly jumps ahead a large chunk of time. When it does this I cannot seek backwards on the timeline as the cursor will not move back. It will seek forward. I have flow control disabled. I have turned commercial detection on and off and the problem continues either way. Today I moved my channels server to a completely different computer with a fresh install and already have the same problem tonight. It occurs while watching recordings of in progress shows or completed and processed shows. I have repaired timestamps and index which does not help. I have toggled surround sound on and off. I am using the server remotely and I use a shield pro and multiple fire tv sticks as clients. Server is 64bit on Windows 10. All connections at the server are wired cat 6. All connections for remote clients are also wired. Internet is 100/100 mbps. I would appreciate any help that can be provided.
Sometimes the recording skips ahead 15 minutes sometimes it is only 2 or 3. It is becoming very frustrating. I do not see anything in the logs.
