Playback stops after few minutes, with TLS Handshake errors in log
I have encountered this with multiple separate Fire TV sticks and Chromecast with Google TV devices using remote access, from two separate locations.
While watching live TV, playback will suddenly stop and go back to the TV Guide. In the log, I see these lines showing up quite a bit:
2022/01/21 10:09:13.197245 http: TLS handshake error from (remote IP of my client):59602: EOF
2022/01/21 10:10:05.319230 http: TLS handshake error from (remote IP of my client): read tcp 10.36.10.38:8089->(remote IP of my client):59606: read: connection reset by peer
This doesn't seem to happen if watching while on a local network with the DVR server, though I use Apple TV and xTeve/Plex with no problems.
It looks like this is happening with version 4.1.0 and 4.1.1 of the app on Chromecast, and 4.1.0 on Fire TV Stick.
Server version is 2022.01.15.1918. These problems +seem+ to have started after my Channels DVR server lost power, but that could be a coincidence. FWIW, I'm running Channels DVR in Docker on Unraid.
It seems like playback stops anywhere from 5 minutes to 30 minutes.
I've also tried reducing streaming quality to see if that helps, but doesn't seem to have any effect.
I submitted diagnostics.
This would indicate some kind of network connectivity issue.
If you can update to latest v4.1.3 that might help
Sadly I am also experiencing this, all fire sticks fine local but remote the logs state the same and all set to auto update apps and server, not running beta. Is there a current known issue?
Update to v4.1.3
