Been watching some recorded programs via the web player and I have been experiencing unexpected stop in the playback. Here are some of the logs. Playing back via MS Edge (Chrome). Channel recorded via PRIME.
2020/03/14 14:59:47.229961 [ENC] Starting encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-0-105188653 at 0 (0.000000) (encoder=h264_nvenc, resolution=720, deinterlacer=blend, bitrate=10000 segment_size=0.01)
[mpegts @ 00000000025cb9c0] Dropped corrupted packet (stream = 1)
[mpegts @ 00000000025cb9c0] Dropped corrupted packet (stream = 2)
2020/03/14 14:59:52.316380 [ENC] Request for 25 is more than 10 from the last encoded segment of 7
2020/03/14 14:59:52.363346 [ENC] Stopped encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-0-105188653 after encoding 0 to 7
2020/03/14 14:59:52.379334 [ENC] Starting encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-25-536333835 at 25 (33.264967) (encoder=h264_nvenc, resolution=720, deinterlacer=blend, bitrate=10000 segment_size=0.01)
[mpegts @ 000000000269bc80] Dropped corrupted packet (stream = 1)
[mpegts @ 000000000269bc80] Dropped corrupted packet (stream = 2)
2020/03/14 14:59:57.108005 [ENC] Request for 18 is lower than current start segment of 25
2020/03/14 14:59:57.156973 [ENC] Stopped encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-25-536333835 after encoding 25 to 32
2020/03/14 14:59:57.171962 [ENC] Starting encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-18-281897454 at 18 (24.489533) (encoder=h264_nvenc, resolution=720, deinterlacer=blend, bitrate=10000 segment_size=0.01)
[mpegts @ 000000000063bc80] Dropped corrupted packet (stream = 1)
[mpegts @ 000000000063bc80] Dropped corrupted packet (stream = 2)
2020/03/14 15:00:02.716410 [ENC] Encoder stopped for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-18-281897454 after encoding 18 to 24
2020/03/14 15:00:02.733402 [ENC] Starting encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-33-796578927 at 33 (41.272967) (encoder=h264_nvenc, resolution=720, deinterlacer=blend, bitrate=10000 segment_size=0.01)
[mpegts @ 00000000025dbc80] Dropped corrupted packet (stream = 1)
[mpegts @ 00000000025dbc80] Dropped corrupted packet (stream = 2)
2020/03/14 15:00:04.717007 [ENC] Request for 10 is lower than current start segment of 33
2020/03/14 15:00:04.766972 [ENC] Stopped encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-33-796578927 after starting from 33 without encoding any segments
2020/03/14 15:00:04.775966 [ENC] Starting encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-10-637151490 at 10 (12.911301) (encoder=h264_nvenc, resolution=720, deinterlacer=blend, bitrate=10000 segment_size=0.01)
[mpegts @ 0000000000ddbc80] Dropped corrupted packet (stream = 1)
[mpegts @ 0000000000ddbc80] Dropped corrupted packet (stream = 2)
2020/03/14 15:00:10.659825 [ENC] Request for 34 is more than 10 from the last encoded segment of 17
2020/03/14 15:00:10.718784 [ENC] Stopped encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-10-637151490 after encoding 10 to 17
2020/03/14 15:00:10.733773 [ENC] Starting encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-34-491533121 at 34 (42.273967) (encoder=h264_nvenc, resolution=720, deinterlacer=blend, bitrate=10000 segment_size=0.01)
[mpeg2video @ 0000000000643440] slice below image (61 >= 45)
Error while decoding stream #0:0: Invalid data found when processing input
[mpeg2video @ 0000000000643440] ignoring pic cod ext after 0
[ac3 @ 0000000000643c00] exponent -2 is out-of-range
[ac3 @ 0000000000643c00] error decoding the audio block
F:\Recorded TV\TV\Jimmy Kimmel Live!\Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg: corrupt decoded frame in stream 2
2020/03/14 15:06:59.466124 [ENC] Stopped encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-569259910\encoder-34-491533121 after encoding 34 to 1131
2020/03/14 15:07:25.910279 [ENC] Starting encoder for Jimmy Kimmel Live! S17E212 Pete Buttigieg Patrick Stewart Tony Hale Jhen Aiko Miguel 2020-03-12-2335.mpg in F:\Recorded TV\Streaming\file3606-ip192.168.50.11-578771557\encoder-379-229958272 at 379 (408.072742) (encoder=h264_nvenc, resolution=720, deinterlacer=blend, bitrate=8000 segment_size=0.01)
[mpegts @ 000000000265bc80] Dropped corrupted packet (stream = 1)
[mpegts @ 000000000265bc80] Dropped corrupted packet (stream = 2)
[mpeg2video @ 0000000002661640] slice below image (61 >= 45)
[mpeg2video @ 0000000002661640] ignoring pic cod ext after 0
[ac3 @ 00000000026630c0] exponent -2 is out-of-range
[ac3 @ 00000000026630c0] error decoding the audio block
