Playlist auto play question
Is it possible to set the playlist auto play to play the first item in the playlist, instead of the next? Let’s say I play a video in the middle of the playlist, I’d like Channels to then play the first item in the playlist, instead of the next item. Is this possible?
No, playlists play in order. If you’d like it to play in a different order, you can manually order them in your preferred order, or use the different sort values.
