PlayOn Cloud recordings frame rate?
I know when it records in what they call Full HD (1080p) that it uses variable frame rate HEVC.
My question is what is the frame rate for the normal HD (720p) recordings?
If it's a fixed frame rate (29.97/30/59.94/60), I can use it since I want to edit the ads out and resave it.
If it's variable frame rate, I can't use my video editor, so wouldn't be interested.
Anyone using it know the answer?
It’s wacky as well. It’s not great. Their tech is using screen capture from a browser window. It’s why the audio is stereo.
It’s not terrible for convenience or kids, but I wouldn’t call it archival quality.
Most people wouldn’t notice though.
So does mediainfo or a like tool display what the frame rate is for the 720p HD recordings?
Guess the only way to know is trial it myself.
My video editor (VideoReDo} doesn't handle variable frame rate.
General
Complete name : D:\ChannelsDVR\PlayOn\TV\Bob's Burgers\Bob's Burgers - S5E8 - Midday Run.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 358 MiB
Duration : 26 min 2 s
Overall bit rate mode : Variable
Overall bit rate : 1 924 kb/s
Collection : Bob's Burgers
Season : 5
Part : 8
Track name : s05e08 - Midday Run
Performer : Bob's Burgers
Performer/Sorted by : Bob's Burgers
ContentType : TV Show
Cover : Yes
Comment : When Tina is up for a hall monitor promotion, she is determined to do whatever it takes to nab the job so she enlists the help of Gene and Louise. Back at the restaurant, Linda begins to decorate the walls with customer artwork on napkins.
AdDuration : 254317
AirDate : 2015-01-04T12:00:00
HasChapters : 1
MaxAudioJump : 0.00
MaxSourceFps : 27.76
MaxVideoJump : 0.00
MinSourceFps : 24.67
PLVF : 1
SubsLanguages : eng
SubsTrack_eng : (Binary)
TotalAudioJumps : 0
TotalVideoJumps : 0
Title/Sort : s05e08 - Midday Run
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Format settings, GOP : M=5, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 26 min 1 s
Bit rate : 1 726 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 27.609 FPS
Minimum frame rate : 1.000 FPS
Maximum frame rate : 1 000.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.068
Stream size : 321 MiB (90%)
Menus : 4
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration_LastFrame : -13 ms
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 35.3 MiB (10%)
Default : Yes
Alternate group : 1
Menus : 4
Text
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Duration : 25 min 42 s
Bit rate mode : Variable
Bit rate : 115 b/s
Frame rate : 0.462 FPS
Stream size : 21.7 KiB (0%)
Language : English
Default : Yes
Forced : No
Alternate group : 3
Menus : 4
Thank You!
Rules out PlayOn for me.
I used the trial period of PlayOn to see what it was like and I was not impressed.
I don't like the random frame rates.
The full HD had visible artifacts mostly on dark/black areas.
As maddox mentioned, the average Joe/Jane probably would not notice.
It's a pass for me.
