Hello all.
I'm new to ChannelsDVR and am really loving it but I have a problem.
ChannelsDVR worked perfectly from my home network.
I also run Playon to record and then watch them on ChannelsDVR.
Now I'm at a resort and the system is setup with AppleTV using a the Savant system.
I'm not super familiar with the Savant system.
Anyways, I downloaded ChannelsDVR app and it connects fine to my remote Channels Media Server.
I can watch through TV Everywhere plus I can record from TV Everywhere and can watch those recordings but I can NOT watch a recording done via Playon (in my home network).
It spins and spins and then after about 10 minutes it'll say Recording Corrupted -17.
I can play the recording fine from my laptop in a web browser for Channelsdvr.
I've put a support ticket in to ChannelsDVR but have not heard back yet.
I can remote into my home computer/media server.
I've run the Channels diagnostics and everything is fine.
From the ChannelsDVR, I sent diagnostics reports to support and notified them in my support ticket.
I went to this IP and actually can see something but I have NO idea what it means. lol
192.168.130.86:57000/log (IP listed on AppleTV Ethernet)
I'm guessing I'm stuck b/c of this Savant setup but I don't know-just putting it out there.
Any help would be appreciated.
Thanks,
pk
I don't know how to include that AppleTV/Savant log here. It's pretty long.
Here is the Channels log and how it ended:
2025/09/17 18:51:01.233168 [HLS] ffmpeg: file37-ff4b16274443: Error opening output file C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1751-1936115532\stream.m3u8.
2025/09/17 18:51:01.233168 [HLS] ffmpeg: file37-ff4b16274443: Error opening output files: Invalid argument
2025/09/17 18:51:01.330861 [ENC] Encoder stopped for South Park - s27e04 - Wok is Dead.mp4 in C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1751-1936115532 after starting from 1751 without encoding any segments. Marked segment as failed.
2025/09/17 18:51:34.142482 [HLS] Stopping inactive session file37-ff4b16274443
And here is how the Channels Log started:
2025/09/17 18:50:37.605953 [HLS] ffmpeg: file37-ff4b16274443: [mov,mp4,m4a,3gp,3g2,mj2 @ 0000027517a27340] Could not find codec parameters for stream 5 (Video: png, none): unspecified size
2025/09/17 18:50:37.605953 [HLS] ffmpeg: file37-ff4b16274443: Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (8000000) options
2025/09/17 18:50:37.609543 [HLS] ffmpeg: file37-ff4b16274443: [vost#0:0/h264_amf @ 000002751b500e80] -enc_time_base -1 is deprecated, use -enc_timebase demux
2025/09/17 18:50:37.612949 [HLS] ffmpeg: file37-ff4b16274443: [NULL @ 000002751b521640] [Eval @ 000000e3bd3fcd90] Undefined constant or missing '(' in 'reserved'
2025/09/17 18:50:37.612949 [HLS] ffmpeg: file37-ff4b16274443: [NULL @ 000002751b521640] Unable to parse option value "reserved"
2025/09/17 18:50:37.612949 [HLS] ffmpeg: file37-ff4b16274443: [NULL @ 000002751b521640] Error setting option color_trc to value reserved.
2025/09/17 18:50:37.612949 [HLS] ffmpeg: file37-ff4b16274443: [aost#0:1/copy @ 000002751b466800] Error setting up codec context options.
2025/09/17 18:50:37.612949 [HLS] ffmpeg: file37-ff4b16274443: Error opening output file C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1692-2810927327\stream.m3u8.
2025/09/17 18:50:37.612949 [HLS] ffmpeg: file37-ff4b16274443: Error opening output files: Invalid argument
2025/09/17 18:50:37.724633 [ENC] Encoder stopped for South Park - s27e04 - Wok is Dead.mp4 in C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1692-2810927327 after starting from 1692 without encoding any segments
2025/09/17 18:50:37.731309 [ENC] Starting encoder for South Park - s27e04 - Wok is Dead.mp4 in C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1692-4169993589 at 1692 (1692.658766) (encoder=h264_amf, codec=h264, acodec=copy, resolution=720, deinterlacer=blend, bitrate=4483, segment_size=0.01)
2025/09/17 18:50:37.808706 [HLS] ffmpeg: file37-ff4b16274443: [mov,mp4,m4a,3gp,3g2,mj2 @ 000001961ae57400] stream 0, timescale not set
2025/09/17 18:50:37.828370 [HLS] ffmpeg: file37-ff4b16274443: [mov,mp4,m4a,3gp,3g2,mj2 @ 000001961ae57400] Could not find codec parameters for stream 5 (Video: png, none): unspecified size
2025/09/17 18:50:37.828370 [HLS] ffmpeg: file37-ff4b16274443: Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (8000000) options
2025/09/17 18:50:37.831024 [HLS] ffmpeg: file37-ff4b16274443: [vost#0:0/h264_amf @ 000001961ae5d800] -enc_time_base -1 is deprecated, use -enc_timebase demux
2025/09/17 18:50:37.834260 [HLS] ffmpeg: file37-ff4b16274443: [NULL @ 000001961e996800] [Eval @ 00000081f8bfd410] Undefined constant or missing '(' in 'reserved'
2025/09/17 18:50:37.834260 [HLS] ffmpeg: file37-ff4b16274443: [NULL @ 000001961e996800] Unable to parse option value "reserved"
2025/09/17 18:50:37.834260 [HLS] ffmpeg: file37-ff4b16274443: [NULL @ 000001961e996800] Error setting option color_trc to value reserved.
2025/09/17 18:50:37.834260 [HLS] ffmpeg: file37-ff4b16274443: [aost#0:1/copy @ 000001961ea65bc0] Error setting up codec context options.
2025/09/17 18:50:37.834260 [HLS] ffmpeg: file37-ff4b16274443: Error opening output file C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1692-4169993589\stream.m3u8.
2025/09/17 18:50:37.834260 [HLS] ffmpeg: file37-ff4b16274443: Error opening output files: Invalid argument
2025/09/17 18:50:37.929861 [ENC] Encoder stopped for South Park - s27e04 - Wok is Dead.mp4 in C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1692-4169993589 after starting from 1692 without encoding any segments. Marked segment as failed.
2025/09/17 18:50:37.937007 [ENC] Starting encoder for South Park - s27e04 - Wok is Dead.mp4 in C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1693-818179517 at 1693 (1693.659747) (encoder=h264_amf, codec=h264, acodec=copy, resolution=720, deinterlacer=blend, bitrate=4483, segment_size=0.01)
2025/09/17 18:50:38.010095 [HLS] ffmpeg: file37-ff4b16274443: [mov,mp4,m4a,3gp,3g2,mj2 @ 0000021cb8519900] stream 0, timescale not set
2025/09/17 18:50:38.035193 [HLS] ffmpeg: file37-ff4b16274443: [mov,mp4,m4a,3gp,3g2,mj2 @ 0000021cb8519900] Could not find codec parameters for stream 5 (Video: png, none): unspecified size
2025/09/17 18:50:38.035193 [HLS] ffmpeg: file37-ff4b16274443: Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (8000000) options
2025/09/17 18:50:38.038091 [HLS] ffmpeg: file37-ff4b16274443: [vost#0:0/h264_amf @ 0000021cb85229c0] -enc_time_base -1 is deprecated, use -enc_timebase demux
2025/09/17 18:50:38.041341 [HLS] ffmpeg: file37-ff4b16274443: [NULL @ 0000021cbc173640] [Eval @ 00000083c15fce80] Undefined constant or missing '(' in 'reserved'
2025/09/17 18:50:38.041341 [HLS] ffmpeg: file37-ff4b16274443: [NULL @ 0000021cbc173640] Unable to parse option value "reserved"
2025/09/17 18:50:38.041341 [HLS] ffmpeg: file37-ff4b16274443: [NULL @ 0000021cbc173640] Error setting option color_trc to value reserved.
2025/09/17 18:50:38.041341 [HLS] ffmpeg: file37-ff4b16274443: [aost#0:1/copy @ 0000021cbb9d8880] Error setting up codec context options.
2025/09/17 18:50:38.041341 [HLS] ffmpeg: file37-ff4b16274443: Error opening output file C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1693-818179517\stream.m3u8.
2025/09/17 18:50:38.041341 [HLS] ffmpeg: file37-ff4b16274443: Error opening output files: Invalid argument
2025/09/17 18:50:38.124315 [ENC] Encoder stopped for South Park - s27e04 - Wok is Dead.mp4 in C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1693-818179517 after starting from 1693 without encoding any segments
2025/09/17 18:50:38.131379 [ENC] Starting encoder for South Park - s27e04 - Wok is Dead.mp4 in C:\channels-data\Streaming\sessions\file37-ff4b16274443-1010672969\encoder-1693-846415424 at 1693 (1693.659747) (encoder=h264_amf, codec=h264, acodec=copy, resolution=720, deinterlacer=blend, bitrate=4483, segment_size=0.01)
2025/09/17 18:50:38.185500 [HLS] ffmpeg: file37-ff4b16274443: [mov,mp4,m4a,3gp,3g2,mj2 @ 000001f0c086a800] stream 0, timescale not set
LOG
