Please help choosing device
Hello, I am looking to buy a device to run channels dvr on and I can afford one of the two mini pcs from the links I will post below, but I am new at this so I would appreciate it if someone could first help me know if these devices can run channelsdvr as servers and if so which one would be best, Thank you so much!
https://a.co/d/0LGj27V
https://a.co/d/a7P1RMK
Don't go for either of them, and go for a known named brand that many in the Community are already using:
https://www.amazon.com/Beelink-Computer-Desktop-Display-Ethernet/dp/B0BVFXCJ2V
Take that device and load Ubuntu server on it. Then install docker/portainer and you will have a powerhouse of a media server that will run Channels plus all the other associated docker projects. You will have a rock freaking solid setup...
You mean the one that the gentlemen from the above response suggested, the thing is I have just enough money to afford one of the 2 I posted in my question, is there any device that you could suggest within that price range even if its neither one of those 2? Thanks in advance!
Question to anyone: Does it have WIndows 11.
The specs on Amazon do not mention inclusion of Windows 11,
although only two comments mention it.
I’m not sure what you’re seeing but I clicked the links, all three are on sale, and the increase for the recommended one is only about $10 more…?
Both that I provided links for in my initial questiion have Windows 11 pro on them, thanks in advance
Yeah believe it or not I dont have those extra 10 dollars lol, it has to be a max of 130 dollars, thanks in advance
Asked and answered. Closing this.
