Please help with SeriesID in advanced passes
Enter the URL using the Hyperlink tool icon. Click the two chain links icon
brave_screenshot_community.getchannels.com (1)
Then enter the url in both fields
http://192.168.1.99:8089/dvr/groups/movies/matches?q=%22Midsomer+Murders%22
No. You have to create the pass while results are in the guide data for the image to appear.
Once you have at least one episode of the series in your library (after the first recording), you can change the picture for the show.
You can select the picture (click on it) and you will see action icons on it:
Click on the pencil icon and you'll be able to change the picture:
He was asking about the artwork for the Pass, not the Show.
If what the pass is looking for is not already recorded or in the current guide data, you don't get the artwork for it.
Screenshot 2026-08-25 at 12-26-31 Channels Passes
Ah yes, thank you for the correction.
