PLEX and Channels DVR
Has anyone been successful using Channels DVR inside PLEX as a live tuner?
If so, how? Are you using threadfin?
Can watching plex away from home pick up TVE channels LIVE or watch their programmed recordings?
Channels is phenomenal , using it with PLEX would be nirvana
TY
Ahem
It worked yesterday in Plex and today even in channels my m3u playlists won't populate thought the epg does. TVE does work just not m3u from an IPTV source
This is the error I get
The media could not be loaded, either because the server or network failed or because the format is not supported.
It worked perfectly yesterday and even if i go to IPTV source, the stream functions properly
It could be that your IPTV source is not very reliable.
Are you able to use VLC with the playlist?
This has been reported many times:
https://community.getchannels.com/search?expanded=true&q=media%20could%20not%20be%20loaded%20either%20because%20the%20server%20or%20network%20failed
Use a non-Chromium based browser.
Can you recommend a non chromium browser? It would have to play nicely with Plex too.
I just don't understand why, overnight it has turned to what it is
Switching from HLS to mpeg-ts has helped some though
Also, using the IPTV page itself a particular channel or stream loads fast and perfectly so it's not the IPTV
Firefox.
Safari (MacOS) works fine to.
I shall try that. Thank you !
Ever so slight difference with Firefox?
For PLEX locally or remote which is preferred HLS or MPEG-TS Also for watching live in Channels?
Thanks for all the help !
ALSO TVE PERFECT just IPTV
I'm just grateful to the geniuses here who showed me how to get Channels to play nicely with Plex
