Pluto appears to be not working
I am getting Playback Failed on Pluto ... I am using Docker.
2021/03/25 07:37:47.394429 [HLS] Starting transcoder for channel 9011 from 2601:1c1:c100:33b0:e853:d83e:c024:e6c4 (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2021/03/25 07:37:47.405587 [HLS] ffmpeg: ch9011-dANY-ip2601-1c1-c100-33b0-e853-d83e-c024-e6c4-remux: pipe:: could not find codec parameters
2021/03/25 07:37:47.447891 [HLS] Couldn't generate stream playlist for ch9011-dANY-ip2601-1c1-c100-33b0-e853-d83e-c024-e6c4: Stream stopped
2021/03/25 07:37:47.448474 [HLS] Stopping transcoder session ch9011-dANY-ip2601-1c1-c100-33b0-e853-d83e-c024-e6c4
2021/03/25 07:37:47.448566 [TNR] Closed connection to M3U-Pluto for ch9011 Pluto TV Fantastic
Am I the only one with this problem ?
No issues with Pluto here.
In the M3U settings for Pluto, change the stream type to HLS
Thanks that did It must have changed it by accident when I moved it over to the NAS Docker from my Windows docker.
Funny thing is that I thought it used to be MPEG-TS.....but when I checked my settings it was HLS. I then recreated your error with the MPEG-TS setting.
