Pluto EPG not showing in guide
This was working previously...
I have the maddox/pluto-for-channels installed in docker on my Channels rpi. In fact, I have two versions a UK one and another instance which runs through a VPN container for US channels.
In the last few days both the UK and the US epg data has disappeared from the guide. I have reinstalled both pluto instances and the epg and playlist files are created sucessfully, the channels appear in the guide but the epg does not. I have the epg set to update every three hours and looking at the logs and the content of the epg file everything appears fine.
Has anyone else had this problem and know of a solution?
I'm on version 2021.02.04.1931.
Is the data missing from the DVR web ui as well?
Yes, its missing from the webui and the channels app. I am having problems generally with the EPG for OTA (as are others) so not sure if there is something going on with the guide database more generally
