I am new to docker. I got the container running for Pluto for Channels. Ran the script which in the log says it created the files. The Github says to find the playlist and EPG via the status page. What does this mean and how do I do it? Thanks
You can view the status page by going to the IP address of the container + the port number you picked when setting up the container.
Example: IP address 192.168.1.1 Port #: 8080
Using a web browser, enter the IP address and port number (using the example above for demonstration only) using this format:
http://192.168.1.1:8080
Note that you have to use the IP address and port of the container you setup. I have no way of knowing this information.
Yeah, I finally figured it out! Working like a charm now that I have it setup in Channels. Guide looks good and I can record. Thanks!
