When I update the Pluto for Channels Docker Container, it errors out on the first run.
To update, I stop and delete the container, delete the image and issue a run command to load the new one. Pretty sure it's happenned on every version since I started using it, just figured I'd report it. I haven't waited 3 hrs to see if it recovers, I just stop/start or restart the container and it works.
Here's the latest one from starting the v1.2.9 container
2021-10-22 01:59:05 stdout [INFO] Grabbing EPG...
2021-10-22 01:59:05 stdout http://api.pluto.tv/v2/channels?start=2021-10-21%2018%3A00%3A00.000-0700&stop=2021-10-22%2000%3A00%3A00.000-0700
2021-10-22 01:59:05 stdout http://api.pluto.tv/v2/channels?start=2021-10-22%2000%3A00%3A00.000-0700&stop=2021-10-22%2006%3A00%3A00.000-0700
2021-10-22 01:59:05 stdout http://api.pluto.tv/v2/channels?start=2021-10-22%2006%3A00%3A00.000-0700&stop=2021-10-22%2012%3A00%3A00.000-0700
2021-10-22 01:59:05 stdout http://api.pluto.tv/v2/channels?start=2021-10-22%2012%3A00%3A00.000-0700&stop=2021-10-22%2018%3A00%3A00.000-0700
2021-10-22 01:59:10 stderr (node:13) UnhandledPromiseRejectionWarning: Error: getaddrinfo EAI_AGAIN api.pluto.tv
2021-10-22 01:59:10 stderr at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26)
2021-10-22 01:59:10 stderr (node:13) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
2021-10-22 01:59:10 stderr (node:13) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
2021-10-22 01:59:14 stdout
2021-10-22 01:59:14 stderr mv: can't rename '*playlist.m3u': No such file or directory
2021-10-22 01:59:14 stderr mv: can't rename '*epg.xml': No such file or directory
2021-10-22 01:59:14 stdout Last ran: Thu Oct 21 18:59:14 PDT 2021
