Pluto Guide is by hour, not program, so I cannot Record entire program
I wanted to record an old movie that started at 1:15 pm on a Pluto channel.
Well, the Pluto Guide is organized on the hour, on Channels DVR. ( I am using a m3u file for Pluto). For example, there was a 1:00 program than ended at 2 pm. So when I setup the DVR to record, it only recorded 1-2 pm, not until the end of the movie, which was about 90 minutes.
How do I fix this?
Use this as your Pluto source instead of the m3u you are using.
Will your source provide better guide, like actual Show title and proper start/ending time slots? How long does it take for new guide to update? What is this "Docker" thing? Thanks for the idea!
Yes.
A minute or two.
That thread provides a method to get the m3u and guide data without requiring Docker.
Works much better.Thanks! Any other sources I can look at besides Pluto?
