Port Forward on Unifi
Would anyone know how to port forward correctly on Unifi for my server. My server is on local:8089
WAN port should be 8089 too. Also, you should use the IP address of your Docker host, not one of Docker's internal subnets.
Thank you, also a big thank you for the olivetin assistance, I saved the docker and had to reinstall because I ran Ethernet in my new build and setup unifi cloud gateway fiber.
Also, if you have setup a manual port forward, you should set it as such in the Channels DVR settings, rather than "Automatic". (In best practice, you should never use "automatic" or "UPnP", and ensure such a setting is disabled in your router.)
For Security reasons :wink:
