Trying to set up remote access from my channels DVR. It is running on my mac os which stays on all the time and has a 4tb external drive attached to it. Everything I find on the internet says my router isn’t compatible and when I enable it manually, it still doesn’t work. Any suggestions for this router?
Once you enable manually, you can leave the box unchecked.
