I am trying to determine if PositivTV can be added as a custom channel into TVE. I've been told there has to be livestream on their website which it appears they do:
I'm not sure how to create the M3U playlist to see if this can work. Does anyone have some experience with this. Thanks for any assistance you may provide.
It has guide data.
If you just added the channel, try going to your Channels DVR web UI
Settings>Guide Database>Maintenance>Delete and Recreate Database
That will pull in the guide listings.
P.S. There are probably other ways to do it, but since a lot of this hasn't been documented, it works for me.
Just wanted to add for others that may be recording this channel.
Like other "Free" Channels DVR TVE channels, the guide data for this channel isn't 100% accurate either.
Appears that gracenote is the only one that can fix that.
