Possible bug in TV guide channel assign
I created a channel source using an m3u file as the source. I loaded that into Channels and saw that all my channels appeared in the lineup. I used the plus sign next to each channel to link a guide entry to the channel. I realized later that I had assigned the wrong guide to a channel. When I went back to fix that the channel name I had given that entry in my m3u got replaced. I don't know where that entry came from. I checked the settings for that source to verify that I set both the channel numbers and logos to come from the m3u file. Is there something I can do to fix this or is it a bug?
Could be you're missing channel-id tags
