would it be possible to do something like the kodi add-on for MLB.tv does and put the home and away feeds for each game into channels as a source? kodi uses the MLB API to log into your account and then pull each feed...
...not the same thing - assuming @crackers8199 is asking for the MLB.TV internet feeds, i.e. for out-of-market feeds.
To be added to Channels it must support TVE, and have a live channel that guide data can be attached to. I don’t believe MLB.TV has either.
i wasn't suggesting it had anything to do with TVE. i know this is something completely different, i was suggesting it as a feature add. similar to how it would look on directv or a cable guide if you subscribe to extra innings.
hell, same premise could be used to add NBA and NHL as well, i believe they both have online packages available.
correct.
